lowpass gate¶
- level control
- CV modulation depth
- signal input
- trigger input (converts any gate to short pulse. You can use Depth knob to control polarity)
- CV level input
- signal output
- LPG/Combo mode switch (LPG has more resonance, Combo is closer to VCA with more high frequencies)
- signal pass level indicator
Description¶
Vactrol-based lowpass gate module. A lowpass gate combines a VCA and a lowpass filter in one circuit — as the gate opens, both volume and brightness increase together. Vactrols provide a natural decay characteristic: even with instant trigger, the sound fades out smoothly due to the vactrol's inherent release time.
Control methods¶
The gate can be controlled in three ways:
- Level knob: manually open the gate
- CV level input: control via CV signal; the Depth knob acts as an attenuverter
- Trigger input: accepts gates or triggers; gates are converted to short pulses for sharp attack with natural vactrol decay. The Depth knob also affects trigger polarity: turn right for pulses on gate rise, turn left for pulses on gate fall.
Modes¶
- LPG mode: more resonance, classic lowpass gate sound
- Combo mode: closer to VCA behavior with more high frequencies passing through
Power consumption¶
384 mW
Links¶
- 🔌 Schematic
- 🛒 Product page
- 💬 Forum discussion
